ExpressCard serial adapters
dschlic1
Oct 2009
Valrico, FL
My new notebook computer not only does not have a serial port, it also has the new ExpressCard slot. Can anyone give some recommendations for serial (RS232) that will work with most PLC comms?
I've just upgraded my laptop as well.
Because I require serial, IT got me a Serial ExpressCard/34 made by Manhattan. (Model #158008).
It has worked well for everything I've thrown at it with the exception of an AB PIC.
However I find it a pain to use because the card pops out when I'm plugging a cable in.
I recommend the USB options.
Yes - express cards are an absolute pain and fall out/disconnect all the time. I tried 3 brands and threw them all away!
Thanks Mickey....
Yes the auto config does work with the Keyspans
I have been looking for an express card to sell for some time now but have not found one that is good enough and is priced right to resell, I think Chris is selling one...
Express card are somewhat like Windows Vista! Soon they will be history.
I tried 3 different adapters... from Express to standard PCMCIA on my latest Dell PC. None worked with the ControlNet PCMCIA adapter ... that was a year ago... before the USB version came out.
The best USB adaptor is IMHO Keyspan.
I had them work with all kinds of funny stuff.
The only anoyance I have found is that some software will keep the dedicated com port number active even when the keyspan is disconnected. So you have to go into the Control panel to erase them ... unless the application can be connecting through port com14 ... then next time com15 ... and so on.
Does anybody have any experience with an ExpressCard to PCMCIA adapter? In a nutshell..... My company purchased new laptops that do not have...
78
61,805
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
197
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
192
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
335
I have lm9030 program on my toughbook CF-29 cannot get my program to hook up with the serial port.
83
