EZ3 HMI will not communicate with PLC
TMcDaniel
May 2020
Florida
41
I have an AVG EZ3 HMI that i am using with an AllenBradley Micrologix 1200. It is a new setup plc program and HMI project. I can not get the HMI to communicate with the PLC. Im pretty sure it is just an issue with the way i have the communication parameters set. The Baud, Parity, Check sum, and Stop Bits are all the same. I have upgraded the firm ware, used 2 different cables (they came off working PLC's). The connector on the HMI is female and so is the cable end so i am using a gender bender to make the connection. Does anyone have any more ideas for me to check before i go insane? Any help would be appreciated. Thank you.
I am plugged into the com1 port. I was on the phone with tech support and told them where i was plugged into and they didnt say anything about it. So im guessing your telling me i need the correct cable. Ive ordered things from you before can you give me the correct cable part number i need. Thank you
I dont make them (only the programming cable), but from what I am reading in the manual page 15 to me you need a DB9 x DB15 adapter, the PM02 you have is the same 2,3 and 5, you can ring out the PM02 cable you have a make your own ?
My company is working toward standardizing HMI panels. EZTouch is the brand that has been chosen to go to. (I was not part of the debate on which...
1,694
143
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
54
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
77
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics show not only blower...
102
