Facon FBs PLC - TekDrive VFD - Weintek MMI
rakeshndas
Dec 2004
Trivandrum
Hello,
In one of my application, I use Facon FBs PLC, Tek Drive VFD and Weintek MMI in the following fashion. PLC - VFD in modbus, PLC other PLCs in high speed link and PLC MMI through serial port. So in order to debug / alter the program I have to remove the MMI link each time.
Can I use weintek MMI in the Modbus same to VFD ? The VFD supports only 9600 baud, 8E2 port settings. Also in the weintek MMI configration, I have a Facon driver and so I directly address the registers. In the settings, will it work if I select RS485 2W and baud rate same to the Modbus ? Shall I have to address the Modbus table in PLC the modbus 8bit address or the dedicated facon addressing ??
Regards.
good afternoon to all! this is the first time i had project with fatek facon plc fbn-20mct, during input checking the expansion unit input signal...
2,351
HI, Does anyone knows HOW TO MAKE ONLINE with PLC FACON / FATEK type FBe ? What toll that I have to prepare ? especially the cable...
1,765
Hi, I have PLC type FBE-28MU from brand FACON / FATEK, Taiwan. Can somebody help me to get the SOFTWARE for ONLINE comunication between my...
3,009
Hello all, One of our application required a Facon FBs 20MCT PLC with a CBE ethernet card on it which should work as a Modbus TCP Slave for a...
4,767
Hello, I have come across an application where I have to use a Facon FBs 20MCT PLC with 3 servos for a table positioning application. How ever...
3,431
