zachary.wilson
Howdy Everyone,
So today i was working on changing an HMI with factory talk to remove some sensors. I took the chance to add a feature I found on another HMI, pretty much it allows you to type in the fault text in the PLC, and if you get a trigger from the plc, the HMI displays what is written into the Fault text in the PLC. I copied it exactly from the other HMI/PLC program. When I did a test application of the HMI program it worked correctly. I was even able to toggle the alarm bit off, change the text and then toggle it back on and it would work. But when i downloaded it into the program the message is wording like below. Any ideas why it works in the test but not the hmi. Was version 8.2 is what the MER file was created as. thank you.
/*S:0 {[PLC]PLC_FAULT_CALL.FLT.TEXT[0]}*/
