Factory Talk Alarms and Event versions
spaderkung
Aug 2007
South Sweden
389
Although I enjoy reading the rants about the Rockwell products, I hope there is some solution to the following problem.
My products are
FTView SE 8.20 (corresponding license bought for Developer, User and ViewPoint)
Studio 5000 v29 (Logix Designer 29.00.01)
My known problem is that Studio 5000 installs the following in v2.81:
- Factory Talk Services Platform - version 2.81
- Factory Talk Alarms and Events - version 2.81
But with FTView SE the version of these components is 2.80.
So.. with both Studio 5000 and FTview Studio installed on developer PC, then it is not possible to export a FTView prjoct to customer PC with only FView.
My workaround is VM with only FTView Studio installed and I use another for Studio 5000.
But I would like a better solution.
Thanks, hope you've enjoyed.
Thanks, the answer I hoped for. But can I find a package of these components in the download section? I looked but found only the full versions of the software.
I need a full component package because now the customer pc is already shipped and I see it next time on commissioning.
Also a good link to that matrix.
Br
Jon
Hi all, I am currently having an issue with 3 HMI panel view panels with the alarm list showing the incorrect date and time. It shows up as the...
2,306
Hi All, I am trying to make the machine to stop with an alarm “clean lid welder required “ every 10000 cycles. I can trigger an alarm in logic...
1,374
Good day I want to know if it is possible to set up the historical alarms on a Allen Bradley HMI without using a SQL server ? Is this possible...
1,485
So I have Factory Talk ME ver 12 and Studio 5000 ver 32. Hardware is a 2711P_T7C21D8S 7" Panelview Std connected to a CompactLogix L30ER. I am...
2,309
I'm a bit lost when it comes to alarming in Factory Talk SE. ALMA/ALMD device based alarming is pretty straight forward: all state is is in the...
5,596
