Factory Talk, copy file to USB
sayahfar
Nov 2013
Toronto
Hi All,
I am new to FT and i want to use DataLog. I configured it but the file is stored in a constant location that I specifyed at first. I want to move it to USB when data logging is finished.
How can I do this?
Which data logging feature are you using; the internal Data Log Model (and the Trend objects) or the Data Store Plus ActiveX control ?
Do you need to move the data log file automatically when the data log is complete ?
I have done something similar by using an autorun.bat file on the USB drive that copies the datalogs from their onboard location to the USB drive. When I insert the drive, the batch file makes the copies and I remove the drive when it's done.
You could also use a pushbutton or a PLC tag to trigger the Program Launcher ActiveX to run an onboard batch file that does a similar thing.
The only method I'd be concerned about is if you want to save the data log file while the data log is still running, or automatically when it finishes. I don't know of a way to coordinate the data log segmentation (when it starts a new file after a certain number of records or time) and any sort of file copying.
Thanks, I use Data Store Plus ActiveX control and I want to move the file at the end of logging by a PB. which function can I use?
Dear All, I have an old HMI faceplate created as factory talk SE( local ) application. Now, i got a new project and i need to use PanelView...
8,715
Hey all, simple question. Once I create a Macro in my Factory Talk Project, do I need to trigger the macro to run somehow? Or are all macros...
80
202
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
106
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
102
