Factory Talk Data Logging
Engrlife
Aug 2017
British Columbia
41
I am trying to get the data log files from factory talk view studio site edition to a format that is useful to look at. They are being exported to a .dat file (storage format "File Set") from what I can see. Is there a way to import all of these files nicely into excel or something that is readable?
That works well if you don't need to look at them frequently.
If you find access will be often, I would setup the datalog to export to a database as well.
A better solution is to log them to SQL Server. Then using Excel to read the values is a lot easier.
It is important to understand that the File Set format is intended for use with trends. That's it. It is not intended for any other purpose. If you want to see that data in something else, like Excel, then you should use the ODBC format and log to a database. As mentioned, once it is in a database then you can view it in the database or in Excel.
OG
OG
As OG stated, but I will leave you with this...
https://www.youtube.com/watch?v=_a9DWblArH4
Hi Everyone, We are getting an error window whenever I opened the Factory talk asset center Application as "The Database size is critical level...
338
Hi , i currently have data logs running but i need a way to link a tag to them so if there ever not running i can trigger an alarm? what is the...
1,845
I'm trying to setup a trend to save data for two sources (both in a compactlogix) so that tends can be viewed over the past few months. I can...
1,277
How to fetch data from Microsoft sql server into ftv? I wanted to create form and store all the data into sql database... Also i need to search...
5,258
This may come across as an ignorant question as I'm not yet familiar with Factory Talk View, but we have a small system that may be using an AB...
1,317
