Factory Talk Linx communication error
rhysplc
Jul 2021
Leeds
Hi all,
I have a studio 5000 program running & downloaded to a compact logix l24er.
Have decided to make a small hmi screen with a few pumps and valves on.
I want to link the factory talk and the studio 5000 program together so I can use the tags created in studio 5000 to link with factorytalk images etc.
From my understanding I need to go into "communication setup" in FT studio. However I keep getting this error message. (shown in picture)
I have been through some existing threads for solutions, but most are from a few years back. still no luck.
Also every time I open FT studio I get this error prompt saying "An internal error has occurred. you must close FactoryTalk View and stop the FactoryTalk Linx service before continuing. Failed to find the topology node in the configuration.
Thanks in advance.
Hello, I do not see the picture,
What version are you using?
Download and install any Roll-up patch, they are at Aug, Sept not released yet.
If that doesn't work, uninstall all the software for View Studio, download ver 12, and the Roll-up patch.
What is the OS?
Running v.12.00 FT ME.
The error message on communications setup shows this:
I only have Machine edition as my company does not use SE if this is where I am going wrong?
Hard to see the picture. it reads
"unable to communicate with the factorytalk linx server "localhost"
-verify the server name is correct
-verify te server's host computer is running (server says its running on FT)
-verify ethernet cable is plugged in.
I can not see the details of the picture.
ME and ME Station should work, or even the play button or test application.
I see windows 10?
Did you do the Patch Roll-up?
Delete the Server (right click on FactoryTalk Linx ---> Delete), and add it back in.
I have to ask, have you rebooted?
There is a huge tech note for your errors. ID: BF16127 | Access Levels: TechConnect
UAC disabled?
Hi Yes, Windows 10, just done the newest patch update from rockwell.
Just deleted the server and still getting the same errors.
I do not have RSLinx Enterprise on my PC.
You'll have to forgive me I am very new to rockwell and PLC in general.
Could you explain what you meant from below:
"There is a huge tech note for your errors. ID: BF16127 | Access Levels: TechConnect
UAC disabled?"
Thanks in advance
UAC disabled?"
Thanks in advance
Lowering UAC to the lowest setting is the "solution" to many problems.
FYI, FactoryTalk Linx used to be called RSLinx Enterprise. About every decade, they like to rename things, just to keep it interesting.
Edit: Do you have a tech connect contract rhysplc? PM me
UAC disabled?"
Thanks in advance
Tech Note is from the Rockwell Knowledgebase and holds solutions to common problems, but you need a support contract to access the KB.
Google UAC, it is basically anti-virus and anti-malware and prevents virus's from changing your computer settings without your permission.
Rockwell software doesn't work well with UAC.
Honestly what you are experiencing is not normal. I would recommend a clean OS, and reinstall View Studio and do the roll-up patches.
UAC disabled?"
Thanks in advance
The other "biggie" is that you are local admin on your login!!!
Hi all,
Thanks in advance.
You can follow this:
1. Check windows firewall and off all fire wall if turn on
2. Config DCOMCNFG in Registry Editor step by step by link bellow
Hi guys, I'm busy on the migration of old 3G/RS232 modems to 4-5G / Ethernet modems on about 200 pumping stations across the country. To...
456
Hi, I am trying to read data values from CAT generator via monico(redlion) module to be displayed on factory talk view studio via RSlinx...
4,807
Helo All,Iam a beginner in automation field.Iam facing an issue with factory talk linx while doing a project. Itz a migration project from...
2,890
Hello all, I am using Factory Talk View v9 in order to configure my application. In RSLinx Enterprise Server Properties when I put as Computer...
4,044
Hi All We are planning to Install RSLINX and Factory Talk Transaction Manager on Windows server 2012 R2 Machine. Have any of you guys have done...
3,955
