factory talk m.e.
RY_Guthrie
Nov 2011
Las vegas, NV
263
I have a factory talk application that I am having trouble getting to the config screen. I know on the older versions of the software you could reboot them and you would get the little white square in bottom left corner I think? I am using version 8.2 of the software, is that option still available on this version? Or do you have to put a go to config button in?
I think you are going to need either a go to config button, or a USB keyboard.
See KB 119811 (Access Level: Everyone)
The version of the software you are using is not relevant to the revision level of the PanelView. You can create runtime (.MER) files for earlier PanelView firmware revisions.
USB keyboard is definitely the easiest way.
Or you could try rebooting it and ...
1. tap, tap, tap, the screen (touch versions) to make the self-tests think the digitiser is faulty.
2. Hold a key down (keypad versions) to make the self-tests think there is a faulty keypad.
Either way it doesn't run the loaded application.
145
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
73
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
79
Hi Friends; I have a red Explanation Mark on Factory Talk Directory in Task Bar. Before Update the windows and installation of AutoCad it works...
168
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
181
