Factory talk ME can not installed on my computer
jugenzhu1963
Jun 2006
toronto
72
Hi All,
I need some helps on reinstall the factory talk ME 7.0. The software was running good. but my pc was infected by some malware and the software can not start. so i remove the software and try to reinstall it and i got the error message indicating "factory talk view setup can not continue." see the attached.
Anyone saw this before? how can i fix this to install the software again.
Be sure to right click and run the install file as administrator.
If that does not work, try the solutions below:
1.Go to Start Menu and in the Run Box type: regsvr32 C:\Windows\SysWOW64\msxml4.dll and hit Enter.
2.Install MSXML 4.0 Service Pack 3 from: MSXML 4.0 Service Pack 3 (Microsoft XML Core Services) http://www.microsoft.com/download/en/details.aspx?id=15697
3.Turn off Windows XP mode if your operating system is Windows 7 64 bit.
4.Run msxml.msi FTView\System installation folder and select option: Reinstall.
5.Reinstall MSXML 4.0 Service Pack 3 (Microsoft XML Core Services)
Good morning, I have an error that has came up in my factory talkview program, that states the follow: “the firmware of the controller PLC1 is...
3,292
188
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
99
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
96
Hi Friends; I have a red Explanation Mark on Factory Talk Directory in Task Bar. Before Update the windows and installation of AutoCad it works...
185
