Factory Talk MultistateSTATE as a tag
drakecesar
Nov 2019
Monterrey
Hello,
Can you help me please?
I have doing a HMI in Factory Talk, i need to see what state it is a multisateindicator
for example if
MultistateIndicator7= 0 ( is in state 0 right now)
or
MultistateIndicator7= 1
then i can do a expression with it.
can factory talk do that?
PD. Factory Talk View version 7.
Hello,
for example if
or
The multistate indicator will be linked to either a PLC or Local tag, just inspect that value...
maybe you didn't understand me, i already have tags in multistate indicator (image 1)
I need to know which state is (online) to make an expression with that state value. 0 or 1.
Maybe I didn't understand you ....
You DRIVE a multistate indicator to the STATE you want it to be in. You cannot interrogate the state VALUE.
Sounds like your multistate indicators have inter-dependances. Surely you can do the logic in the PLC and keep the HMI indicators as simple as possible.
Don't forget that each of the numbered states can have a "State Value", which does not have to be the same as the state index number. This means it is possible to drive the indicators with bits in a DINT tag.
For example ....
State 0 Value 0
State 1 Value 1
State 2 Value 2
State 3 Value 4
State 4 Value 8
State 5 Value 16
etc.
184
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
99
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
94
Hi Friends; I have a red Explanation Mark on Factory Talk Directory in Task Bar. Before Update the windows and installation of AutoCad it works...
183
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
189
