Factory talk SE to ME
Get in touch with AB. They converted mine for free. But I do have Tech Connect.
And of course not everything will convert. Trends and Data Log models did not for mine.
A number of things from SE do not work in ME.
Last time I did one manually it was a lot working in XML until it would finally import the screen.
most buttons and such don't convert because of how they're specified.
I was able to convert any and every shape/object on the screen though that was any type of polygon by exporting, modifying the text file and reimporting into ME.
This was for a screen where it had hundreds of polygons drawn on it for esthetics (flowers, ground markings, etc. It would have been a huge pain to recreate it).
All the buttons were not save-able though. If someone was inclined enough they could write something to convert them roughly, but it doesn't happen often enough I guess.
The simplest way I found, wasn't to go in and modify the SE. but to create a new window in ME. then open both the SE and ME in a text editor, then copy and paste the code from one to another and it will take it just fine if the option is available for it. Otherwise it will throw an error up.
+1 export both and compare. IIRC it will give you a hint where the error is at, I can't remember if it was a line number or description of what was invalid but I was able to slowly pluck those errors away with a text editor until the objects would come in.
132
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
70
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
68
Hi Friends; I have a red Explanation Mark on Factory Talk Directory in Task Bar. Before Update the windows and installation of AutoCad it works...
157
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
177
