Factory Talk Security Question
bubbleship
Jul 2006
ohio
36
We have a customer that wants 2 levels of security access on the panelview plus (password & removable key selector switch). I have done password no problem, but I never had tied an input on the PLC card. Not sure how to do this or if it can be done? I’m using 1769-L32E Compact Logix with PV+ 1000 Thanks for your Help!
so if the key selector switch is in the enable position (say input 1 is on) than the setup person can login to make changes to a recipe. I'm still not sure how to do this?
Why don't you tie the animation of the log in button to the switch.
So if the switch isn't on then you can't see/press the log in button.
Cheers
Mark
Copy your Recipe File to a Storage File if key is true and changes are allowed.
Then Copy your Storage File to your Recipe File if change is not allowed.
Create a 1 second pulse bit
Now Pulse bit and Key condition will determine if you copy recipe to storage or storage to recipe.
This way when Key switch is off and no change is allowed and someone makes a change. It will be overwritten when the pulse bit is true.
Also this keeps the PLC in Control And Not your HMI.
QUOTE=MarkNightingale;622697]Why don't you tie the animation of the log in button to the switch.
Cheers
Mark[/QUOTE]
Thanks Mark... Didn't think about that 🙃
Hi all, i have some issues with the security accountes. I create an administrator account who doesn't have access to the "Manual control...
6,940
Hi, I'm hoping to secure a network of PLC's (Compactlogix 5000, Various versions, V24 to V29), only accessible to myself and a few...
1,317
HI EVERYONE I am familiar with security application in FTVME. Can somebody tell me if security to a display in FTVME can be applied with only...
7,276
HI EVERYBODY I want to create security for only one display in the application.I have reviewed the factory talk view user manual section...
6,754
Hi , Any body can guide me how to assign User Name and Password to individual object in Factory Talk SE? For example, When operator want to...
2,208
