Factory talk Studio touch input message
grider75
Jul 2014
Illinois
56
I have used the Factory talk on my PC before and have never got this message "Touch input is enabled". It asks if for me to disable the touch input. Isnt this for a PC with a touch screen? Mine does not have that and I do not have the option of turning this input off. Anyone have this problem before? It will not launch Factory talk because of this.
Never mind found the answer on Knowledge base. Had to go into services on my PC and turnoff Tablet PC input service. Don't know how that got turned on but it worked.
This just happened to me this morning, glad I found this post! Same scenario - not using a tablet, no touch screen to speak of. Somehow the *ability* to use one was turned on. Says it is set to be started *manually*. I didn't do it. IDK. Anyway - if you go into services.msc and stop the service, no restart is required to launch FTVS.
LOVE this site. Problem resolved in 4 mins. Thanks for the replies showing the fix!
Not big on conspiracy theories but having this happen to me, day on day a year later.....
Busy fixing a bug, close FTView, open it again, met with this error. Not sure why FTView would check for this or why it matters. And when I click to open the app anyway, open the goddamn app.
grider75 said:
I have used the Factory talk on my PC before and have never got this message "Touch input is enabled". It asks if for me to disable the touch input. Isnt this for a PC with a touch screen? Mine does not have that and I do not have the option of turning this input off. Anyone have this problem before? It will not launch Factory talk because of this...
...Never mind found the answer on Knowledge base. Had to go into services on my PC and turnoff Tablet PC input service. Don't know how that got turned on but it worked.
Better late than never...
It's usually good practice here to post the Knowledgebase technote article so that others can view it. Although the OP did loosely explain the solution, here it is with some extra info related to different Windows Operating Systems...
673970 - FactoryTalk View Studio: Touch input is enabled
Access Level: TechConnect
...Turn if off, and disable it, and possibly reboot machine.
Regards,
George
Hello,
Thanks for the information ... the same issue happened to me.
Except that the service had a different displayed name : Touch Keyboard and Handwriting Panel Service
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
180
I have some global objects, numeric display with associated data that pulls up a pop up screen. for the life of me i cannot figure out how it...
240
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
377
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
692
Hello all, looking for ideas on getting some basic training done, I need to practice on maintenance timers and bypass switches (with a Factory...
1,323
