Factory Talk View ME 7.0 and Plant PAX Issue
ELBroyer
Apr 2015
Indianapolis
Having issues using the Plant PAX objects version 3.0-10.
Software wants to crash when attempting to Test the application. The most common issue that the software is unable to find one of the Face Plates when compiling. Sometimes a reboot of the entire system helps but not always.
Is this a procedural problem?
BTW I am locked into 7.0 on the Factory Talk and 3.0 on the Process Objects.
I went to the site and downloaded the latest patch. The version numbers are the same that I had before but the software is working correctly now.
We had that happen quite a bit with version 7 when moving apps around. Re-apply the patch and then it worked.
Version 8 seems to be better about odd communication issues.
150
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
346
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
302
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
618
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
381
