Factory talk view SE 8.2 toolbar not working
Sep 2014
nc
60
I am currently running Factory talk view SE 8.2 and have ran into several problems when it comes to toolbar. Several months ago, my objects tool bar will no longer dock. I have contacted Rockwell and even had the remote in and they cannot fix the issue. Now the alignment toolbar will not show up at all.
Please let me know if you can resolve this issue.
@operahost
That fixed the issue for the toolbar that could not be located. However, I still need help trying to dock another toolbar. I have clicked the area on the toolbar that is created to make it dock. I have dragged it to different areas.. nothing happens. Rockwell even looked at it and they couldn't fix the issue.
thanks
There is a registry key that holds the toolbar settings.
It's been a long time since I have used that, but deleting the value will reset the toolbars to default. I have used it to recover lost toolbars (on a second monitor, or when changing a laptop from docked to undocked).
If I can find that key I'll let you know.
Search and delete at your own risk.
Well, deleting this key did reset my toolbars.
Code:
HKEY_USERS\S-1-5-21-567238126-2415255155-1568896733-1000\Software\Rockwell Software\RSView Enterprise\Toolbars
If you feel adventurous: close FTStudio, backup/export that registry folder and then delete.
Or ask tech support on their opinion about doing that.
186
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
358
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
309
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
634
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
387
