factory view talk transfer button properties
khewes
May 2016
New Hampshire
123
hi all,
ive defined some button properties perfect but later realized that these buttons were the wrong type, i want momentary instead of maintained and vice versa
is there anyway to transfer properties from a momentary button to maintained button? i dont wanna go thru and add all of these again if i dont have too
Unfortunately no, they are separate object types and they don't let you change that. You should be able to copy and paste some of the properties.
Perhaps if you exported to .XML then you might be able to change it from the XML editor but I suspect that is more work than just recreating the object.
OG
153
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
350
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
303
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
625
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
383
