Factorytalk change Projects path
Tanquen
Jul 2014
CA
163
I’ve got a new PC for a project and it has a small SSD for the boot C drive and a large 930GB RAID D drive. I thought it would be a good idea to put all the application stuff in the D drive but many apps and Rockwell want to put lots of stuff in your users folder. How do you guys handle this? Is there a way to update the FactoryTalk default paths? I did install FactoryTalk View SE on the D drive.
Its Rockwell so it is harder than it should be. :(
I like this: “Any version of FactoryTalk View SE (including 9.0) will not automatically modify these registry keys during the install. The keys must be manually edited.” They should ask you when you change the install path but oh well.
It sounds like they are having you change the location of common Windows folders not changing where Rockwell puts stuff. Lame and sounds dangerous.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
I need to add a pop-up display to an existing PanelView Plus program. However, I'm not understanding what I need to do with the Global Connections...
4,197
Hello, I have a few multistate indicators that I am using to represent what product is in the location that it represents. They are all identical...
1,889
I am replacing a PanelView Standard with a PanelView Plus 7. The application is used for our production lines to order supplies from our...
3,262
