FactoryTalk Clientkeys
DTran
Oct 2011
PTBO
Hello, I'm recently converting a RSView32 project into FactoryTalk SE. What I'm having trouble with is that in the RSView project they have a Clientkeys file that uses VbaExec everytime a certain F-key is pressed. The VBA code that is launched moves the mouse cursor 1024 pixels to the right. Since FactoryTalk doesn't have the VbaExec command, is there anything similar/workaround to what they have?
VBA in Se resides in the screen, not a separate file like 32. Could you post the VBA code for the cursor movement? There probably is a workaround.
Sub MoveCursor(x As Long, y As Long)
Dim dl&
dl& = SetCursorPos(x, y)
End Sub
The Client Keys file just calls this routine with parameters when an F-key is hit
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
31
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
220
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
55
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
110
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
148
