Hello all,
I have to replace the old panel with new PanelView Plus 600 panel. I have already done the conversion of old .PVA file with FactoryTalk import option.
After conversion, I got some .log file about what I should change in new program (conversion was not really good). I will have some questions about that too later, but first if you can help me with communication problem.
After conversion, I opened the Communication Setup to make a communication between computer and panel. I use serial adapter (Moxa) which is connected to my PC on COM3.
In RSLinx I see the panel, but when I try to add the driver to Design(Local) window, I can not see the panel.
In diagnostic window I have error:
DF1: Failed to open '\\.\COM3', error = 0x00000005.
Also, when I add the driver and select it, I have message:
Select a different path - Serial-DF1 cannot be used.
Can someone help me to solve this?
Thanks!
Thanks!
