FactoryTalk EnergyMetrix login problems
Compass
Feb 2015
Goderich
101
Hello.
I'm working on Factorytalk EnergyMetrix
I've been using SQL Management Studio to restore backups of the EMMA file. You see, we lost a great deal of unbacked data, and I was hoping to find something close to the old configuration.
Anyway, the backups are so out of date I decided that it would be better to start over. We just have 6 powermonitors anyway.
While I was checking different backups, I did something wrong somewhere and now I can't log on to energy Metrix.
It starts with
Invalid object name 'SystemConfig"
Stack trace
[OleDbExeption (0x80040e37): Invalid object name 'SystemConfig'
xxxxxxxxxxxxxxxxxxx
If it makes things easier, I'd love to just wipe out our database entirely and start over like this was a new computer. At bare minimum I just need to be able to log on to energymetrix again.
Any suggestions?
A rockell tech helped me through it.
use sql management studio to delete EMMA.mdf and all its connections.
uninstall / reinstall
make sure to install with a login that uses sysadmin credentials or it won't rebuild the database.
if you're daring then try restoring a backup .bak file to the fixed emma.mdf database.
Hello I go to Factorytalk energymetrix and choose Trend. It will generate Trends for the month i.e. 09/09 to 10/09 I can change meter tags and...
2,520
Greetings Today I'm using factory talk EnergyMetrix. We have a trend of KWh wrt time. What my employer wants is line it up this trend with a...
1,621
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
43
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
222
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
