FactoryTalk - Error Compiling: Unsupported feature=Use Variable Min/Max..
dcovemac
Jul 2011
Bruges Area
Hey all,
Made myself a decent application in FactoryTalk, when testing the screens with the "test display" btn everything works fine.
Then I tried to compile..
I always get these errors:
ERROR: Unsupported feature=Use Variable Min/Max; Component type=Displays; Component name=Overview; Object name=NumericInputEnable2
ERROR: Unsupported feature=Use Variable Min/Max; Component type=Displays; Component name=Overview; Object name=NumericInputEnable1
ERROR: Unsupported feature=Use Variable Min/Max; Component type=Displays; Component name=[VAR_Length]; Object name=NumericInputEnable3
Indeed I'm using NumericInputEnable's with variable min and max, but that shouldn't be a reason I can not compile..
Does this sounds familiar?
Thx in advance
Are you creating a Runtime file that is not the same version as your installation of FactoryTalk View Studio ?
I've heard of this sort of error if you use a feature that's available in, say, FactoryTalk View 6.10, but you create a Runtime file for version 5.0.
I'm not sure if the Variable Min/Max versus hard-set Min/Max is a 'new' feature or not.
Thx for the fast reply Ken,
Well actually, yes, I'm compiling in 5.0 with a Factory talk version 6.0
Is there a way to work around this and still be able to compile errorless in 5.0?..
Well I just tried to compile it to 5.1 and this works, guess just I'll update the firmware of the Panelview.
I doubt this was an unsupported feature in 5.0 though.
Thanks for putting me on track Ken!
Grtz,
Hello everyone I have the next issue with FactoryTalk Linx, when i configure the Ethernet driver and try to find the IP Address of the PLC Device...
60
I upgraded Factorytalk activation manager to version 5.01 from 5.00 and since then, Factorytalk Assetcentre stopped working! I receive the...
546
"Failed to Initialize the service {3F883B87-2208-11D4-B0E7-001083022E04}" Along with "Failed to load HMI Server Service" Hello, I am getting...
823
Hello all, I am trying to "Specify a FactoryTak directory" to another computer on the network. But my local admin username and password generates...
1,727
I have uploaded a file from a panelview and i get a message when trying to restore it: "This runtime application file was saved in a protected...
1,396
