FactoryTalk Launch name
faeldebrito
May 2021
BH
I have a FactoryTalk View SE application with 4 clients. These clients are operated from different locations, so I need to somehow identify them through code to perform different actions.
My initial idea would be to put this information in an auxiliary variable, but as all clients would write in this same variable, it would overwrite. If I use more than one variable, then I can't identify via code which variable the specific client is running.
Note: I can't do this through "Computer Groups" or "User" due to internal definitions.
I came to think of some system variable that would inform the launch name or some local variable (that each HMI writes only in its variable, without interfering with the global database), but I don't know if any of these options is possible
I've done this before using some VBA to record the computer name and act accordingly. It was quite a while ago and I no longer have access to that system, so I can't give you any specifics, but it worked.
This I know how to do, but I have another problem at this point: the 4 clients are actually remote connections on a terminal service, that is, it ends up being a single computer
How do I have access to sockets?
That, I don't know, perhaps with help from IT? I'm pretty sure that any remote connection service must be able to distinguish each connection in order to send the correct data, even if they are all requesting the same data from your controller.
It has been a while, but check the environment variable CLIENTNAME in the terminal server session. I seem to recall that is the name of the RDP client machine.
I solved this problem, with the following VBA code:
Set oShell = CreateObject("WScript.Shell")
sPSCmd = "powershell -command (Get-ItemProperty -path ('HKCU:\Volatile Environment\' + (Get-Process -PID $pid).SessionID ) -name ""CLIENTNAME"").CLIENTNAME"
Set oExec = oShell.Exec(sPSCmd)
oExec.StdIn.Close
fClienteName = oExecutor.StdOut.ReadAll
Hello I have installed FactoryTalk Assetcentre V7 on windows 10. When I try to launch the client it will whirl for a bit and nothing. When I...
3,937
Hi guys, I had View studio 6.00 and it was working alright but we were forced to switch for 5.1 because almost all of our panelview are old. So...
5,767
Can anyone think of a way to add a button to an HMI Screen in FTVSE which will launch an windows executable file? I have a customer who has...
2,873
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
200
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
44
