FactoryTalk replace fonts in all displays
bgtorque
Oct 2013
Northampton
127
Is anybody aware of a way to globally replace a font type across all or a number of screens in one hit, but without modifying the font size?
I don't believe there is a native feature. I usually export the screens I want to edit. They will be XML files. Open with a notepad editor. Do a search and replace for the font. Then import back in and update the objects.
James
Late addition to the thread but it may help someone else. I wanted to change all the fonts from 12pt to 10pt ...
For each display
- Open the display
- Select all the objects
- View | Properties
- Click on the Font property
- Click on the ... button
- Set the font properties
It's pretty quick.
For each display
- Open the display
- View | Properties
It's pretty quick.
Are you sure this works for ALL fonts, including embedded? I would be hesitant to say yes.
I had forgotten to reply, I did try this and it doesn't work on all fonts like I thought. For example, it will not change the font within a multistate. For me, the best way is still export, search and replace, then import back in.
It works for me if you change the state in the Property Panel
Good day all, I'm making a Transmitter global object for my displays in Factorytalk View SE and was attemping to use VBA to Replace the...
2,418
Good Morning , I need to upgrade to FactoryTalk View ME to 8.2 , from 6.1. I downloaded 8.2 overnight . I rebooted , and went to open up...
3,053
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
43
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
222
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
