FactoryTalk SE Tag Issues etc.
Jul 2007
Kiruna
600
Hi Guys,
Looking for some advice on how to approach this as I feel i'm really making a mess of this.
I have an SE application communicating to 11 CLX L-55 PLCs. There are a large number of numeric displays which I total values from each PLC etc. The problem then arose when a PLC lost comms or was powered down that the numeric display wireframed and my calculations were also wrong.
I started to then use derived tags and using the expression : If COMM_Err PLC tag then 0 else PLC Tag is equal to Internal tag. The problem now is Im going to have tonnes of derived tags each checking for comms and tranferring data into Memory tags for calculations.
Has anyone any suggestions for this? If a PLC is lost can SE not just write 0 to these values by default?
My main concern is I have a lot of calculations to do and its going to get very messy.
Hope this explains what I am trying to achieve.
Why not do all the calculations in one of the PLC's and then just display the values on the screens. I have never liked doing calculations in the HMI.
Gotcho, I agree with you, but what about if they also lose comm with that plc. It would be better to find out why they are losing comm and try to avoid that. What about comm switch for instance, have they check if it´s compliant with AB requirements ??
Hello all, I am new here and this is my first post so I apologize if I am doing anything wrong. I am working on converting a Wonderware app to a...
8,047
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
299
Expert, Could you advise me some idea how to add tags in Summary Alarm's FilterDefinition? SumView.FilterDefinition = "AlarmShortName LIKE...
917
Hello All. I've been testing an application on both a PanelView and within FactoryTalk on my virtual machine. Testing was going fine until today...
782
Hi All, I'm trying to look into if it's possible to get FactoryTalk SE to build a process log report, recording various tag values at a poll rate...
589
