huangshuai
I record the fault code of the motor in the SE. I can view the data in the trend graph and then save it in the local log file set.
I want to view the fault code and time generated in the past year and count them in excel. Because if you select a certain span to view in the trend graph, it will load for a long time, which is too much trouble. Is there a simpler way that can make me do more with less?:手球:
