FactoryTalk Studio Parameter Files
DBLD99
Oct 2003
USA
230
I have been trying to get Studio ME Station to run on a VMWorkstation. All the screens work accept for the popup screens where I use parameter files on them. It is running XP in VMware on a Windows 7 machine. I have also tried use XP mode on 7 with the exact same problem. Alarms work, Direct tags work, just not parameter files. Of course AB won't talk to me since it is not supported. With it being so hard to order PC's with XP anymore not sure what to do with it. Any idea's.
Your best bet would be to post the .apa file, that way we can have a look and see what is going wrong.
I have FTME in a VM and don't have any problems like your describing.
I know I programmed the screen right because the project is running fine on another computer running XP and a panelview plus 1000. So I know the project is fine - it just wont work on a vmware or xp mode system on windows 7.
Well, I only run FactoryTalk in a VMware VM running XP (Win 7 host) and have no issues with parameter files.
Perhaps you can explain what you are doing, and then what isn't working and maybe we can see what is happening. This below doesn't tell me what you are doing or what results you are seeing.
"All the screens work accept for the popup screens where I use parameter files on them"
Better still, VMware allows you to record a movie. Record the movie and post that.
OG
Hey everyone, I want to make a faceplate in FactoryTalk View Studio and use parameters. Is there a way to provide feedback as to what file...
2,578
Hi All, I am looking at an existing FactoryTalk Studio program and have come across in the parameter file :- #10=/::Alarm0_28.Disabled I...
1,153
All, Thanks for reading this post and for any ideas and suggestions. As stated on one of my previous post, I am in the process of upgrading an...
5,261
I am replacing a PanelView Standard with a PanelView Plus 7. The application is used for our production lines to order supplies from our...
3,274
Hi, Using factoryTalk view studio ver 6 to work on a HMI project. This project is been created by third party vendor and not able to access it...
2,076
