Factorytalk talk knowledge please
stu
Aug 2005
England
784
Hi guys
I’m after some factorytalk view studio Me knowledge, I was looking at the terminal info ocx demo in Ftv studios and I would like to get this to work on our machine ?
Is this a ActiveX ipinfo ?
Do I have to create the memory tags in factorytalk?
I’ve had a look at this but have not attempted. Your guidance would be much appreciated thanks stu
So the stuff on the left is just a display, those memory tags are bound using the ActiveX control 'Me TerminalInfo Control'
Add the control first, then yes you'll need to add memory tags and bind then inside the control.
Well, it seems fairly straightforward.
But you can reference technote 518641 for more information about each tag and what you can/can not do w/ them.
You can also probably just export the display and tag information and import into one of your projects.
You can find info on the activeX in the FTView Studio ME Help>Contents
Search for TerminalInfo ActiveX control
The activeX only works with tags; all of them are write tags except for the "enable" connection.
You will need to build your display objects to show the tag data.
You don't have to create the HMI tags, but you do need tags of one kind.
The example uses HMI memory tags, but you could also use direct reference tags to your PLC.
Can you get the hmi firmware displayed too ??
I don't think so, no. I have not ever done that.
The firmware info is in the config dialogs, but you don't always want the operator to go into the Configuration Mode to see that.
I knew this one sounded familiar?...
Factorytalk me active x set up
In case you are still struggling to figure out what is what here with ActiveX objects in general, this technote gives a good general breakdown of what's involved in adding these objects into an application...
24195 - Using ActiveX objects
Access Level: TechConnect
Any questions, keep them coming and one of us will surely answer you.
Regards,
George
Just copy and paste into your new project, compare the tag addresses to what yours are and change if needed.
The device name can be shown with the terminal info activeX.
This isn't automatic, but you could change the PanelViewPlus device name to include the firmware version. ex. PVPabc_v900.
If you are very diligent about updating the device names with firmware changes, then that could work.
At least it lets you view the firmware version inside the running project.
Hi. I'm trying to ensure that an operator has to enter in a comment into FactoryTalk View Site Edition (ver 8.10). I know that there is an...
4,540
Hi all, I was hoping someone could please give me a hand. I have done a project on FactoryTalk View release 6.10 using a Panel View Plus 600...
4,827
Hello, I want to create a button in my header screen that will acknowledge or silence all the alarms in the A&E Server. I tried the...
8,444
Can an alarm be ACKNOWLEDGED with a ALARM STATUS LIST using FactoryTalk View 5.1?:huh: I have successfully setup the ACKNOWLEDGE ALARM BUTTON...
5,625
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
177
