FactoryTalk to SQL
Julien404
Apr 2022
Quebec
I'm trying to get some data into my SQL database and it seems like FactoryTalk (SE) is not able to write in it. It did successfully create the tables inside of it though. I made a button to run the command DataLogOn for the model I made and I get the message ''Unable to process the following command : DatalogOn test2''. It is my first time working with SQL stuff so any help is appreciated:)
With a comprehensive picture of production status across entire lines and processes, FactoryTalk® View Site Edition (SE) lets you monitor and control manufacturing at all levels, from a single operator station up to distributed server/client, multi-user applications.
For anyone who might stumble on this thread, heres how I fixed it :
- Open the SQL Server management Studio
- In the object explorer : Security/Logins/Right click/New Login
- Click on search and type "LOCAL SERVICE" and then ok
- Do the same thing again but for the user ''SERVICE''
- Double click the users and give them the server role ''sysadmin''
Now it should work.
When you test the connection or write the tables you connect to the database as local user, but when FTV tries to connect it does it as a service.
This error code is also related to that : unable to access odbc data source
Now it should work.
Was hopeful, but this did not solve it for me.
I created the 32-bit ODBC connection by launching the app from the SysWOW64 folder, successfully. Then used that connection in the datalog model, and it successfully created the tables, but I still get this error when attempting to start the datalog from the command line:
Unable to process the following command: DatalogOn someDataLogName
FWIW, it behaved the same whether I used a system DSN or a file DSN.
....but I still get this error when attempting to start the datalog from the command line:
I believe the Command Line is case sensitive. Try "DataLogOn" instead of "DatalogOn"?
Commands are not case-sensitive.
I had trouble years ago using the ODBC format with MS Access. We used Access for some classroom stuff as it was easy to use. I don't remember all the details, but it generated a similar error. In our case it wouldn't let us restart a log that had been stopped. So it did log data, until we stopped it.
We ended up switching to SQL Server Express and once we performed the step Julien404 mentioned (there is a Tech Note) everything worked for us.
OG
Correct, they are not case sensitive.
Did some looking in the Tech Notes, and it says if FT View Studio and the HMI Server are two different computers (which they are), make sure the DSN exists with the same name on both computers. I added the same DSN to the HMI server (32 bit, of course), and still end up with the same error.
If the port wasn't open, it wouldn't make the connection and definitely wouldn't be able to create the necessary tables.
OK, I didn't quite get whether you were creating the tables locally on the SQL server itself, or from the remote computer.
No, I let the datalog model do it natively.
I think I found a resolution. When I first set up the System DSN on both, I used windows authentication (domain-level, same credentials). Now, I created another user within SQL and used that for the SYSTEM DSN credentials on both; and I also checked the "Login Required" box in the datalog model. It started without error now.
Hi, We are doing a project in FactoryTalk View with Database connected to SQL via Connections available within the FactoryTalk View Project. Is...
1,585
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,303
Hi all, I'm trying to open a project with Factory Talk view studio V8.1 but am getting the error: "FactoryTalk View cannot authenticate with the...
3,005
Hi guys on my development VM i have a wired problem. I've set the factorytalk diagnostics to a local file, and also to a SQL Database throught...
3,705
Hi Guys, I have just installed FactoryTalk Studio V10. I am getting the error as per the attached picture. I have tried installing...
8,561
