FactoryTalk Transaction Manager install
curlyandshemp
Jul 2005
Toronto
1,903
I have searched Rockwell web site and knowledge base and can't find an answer to this question.
Trying to install the lastest version of FTTM V10.20.00, during install a get an error stating FactoryTalk Activation V3.62 needs to be installed, and install terminates.
My PC has FT Activation V3.62.11 and cannot be downgraded as I have CPR9 SR7.
Is this a known issue?
The problem you describe sounds like a call to tech support. FTTM is "challenging" to set up. I deployed two systems last year, the first took a long time to set up even with the assistance of Tech Support. The second system only took me two days to get up and running.
Good Luck!
Nick
Install FA 3.60
Actually, you can re-install just the Factory Talk Activation.
I also have had problems with 3.62 and 3.6211. You can uninstall 3.62 and then re-install 3.60 and everything will still work fine. If you don't have 3.60, you can download previous version of Factory Talk services from Rockwell provided your still in support. If not, then the previous version CD, you can install it from there.
Just ran into this same issue. You cannot install FTTM w/ 3.60 either.
There IS a knowledgebase article on this, just that it's labeled as a fix for Win 2012 which cannot install Activation V3.x. Using the executable in the topic I was able to install FTTM without issue.
Hi to all.!!! Is anyone having Interfacing of Control Logix 5562 & FactoryTalk Transaction Manager relevant documents and how its linked with...
1,951
Hi guys, I've got a problem with FTTM configuration. In the step 3 (define data points) of the configuration checklist, when i select an...
2,217
Hi All, I'll looked through the forum and the vastness of google with little luck (which makes me believe what I'm going to ask is not possible)...
3,652
I am trying to add some new transactions to an existing working FactoryTalk transaction manager service (V10.20). One is triggered by a bit (bool)...
2,676
Hello All This is my first Transaction Manager project. I have a working configuration in Transaction Manager 10.20 that successfully writes...
7,648
