Factorytalk View ME Alarm History
Zlinger
Mar 2014
AZ
36
New to FTV. When I have an alarm, it pops up on the alarm banner as it should, but there is seemingly no storage of the alarms after they are gone. I have tried using the alarm list object too. I'm sure it is easy, but I am missing something.
The alarm setup editor help file says "Also use this editor to specify trigger data types, Acknowledge All values, the maximum number of alarms in the alarm history, notification hold times and optional connections." But I am just not seeing where I have the option to store alarm data like date/time, etc.
Any help is greatly appreciated.
In the Alarm Setup, go to the last tab. There you can set the maximum number of alarms in the history.
You don't need to specify any alarm data, date/time, etc. There are no options for that.
The history stores everything for every alarm triggered. It's FIFO and there is no other option. Once the alarm history is full it deletes the oldest alarm messages.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
Hi all. I´ve got a little problem with my FT View SE alarm window. On my PLC program, I have 200 SINT for alarms, in which every bit is for one...
186
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
339
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
446
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
549
