FactoryTalk View ME to SE Migration
Do you want to move just a few screens or are you trying to move the entire application?
If you are moving a few screens, then just go to your new SE application and right click n the Displays editor and select Add Component. Then browse to the folder containing the screens and select them.
If you want to import the application it can be done differently depending on if you are doing an SE Local versus Network application. For Local, create a new application and select Import. If working with a network application, right click on the application (or an area folder) and select Add a New Server and select the HMI Server. Then, I think it is again called Import.
When importing an ME application you will no get your RSLinx Enterprise shortcuts as part of the import. Those must be re-created.
OG
There are plenty of "gotchas" while doing this conversion...
32590 - FactoryTalk View ME to FactoryTalk View SE Conversion
Access Level: TechConnect
Have fun!
Regards,
George
Hi I just migrated a program from panelbuilder 1400e to factorytalk view me, everything seems fine except the alarms. The problem is the...
3,490
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
46
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
223
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
143
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
197
