FactoryTalk View Parameter File Usage
Hey All,
I am running into the same thing. Wondering if a solution was ever found other than changing tag names? I have a parameter number #1 for example immediately followed by another digit (non-character) and it won't work.
From memory, you can just put the .open etc at the io assignment, with the #1..
So if tag = TAG1026 of type motor, make the parameter file ‘#1=TAG1026’
Then where the tag attributes are required, #1.Auto, #1.Run etc
This is from memory, exact syntax might be slightly different
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
453
I will try to explain what I am doing. I have 6 fillers, all of them the same, all of them have 8 heads on each filler. I press a GoTo screen...
1,185
Hey everyone, I want to make a faceplate in FactoryTalk View Studio and use parameters. Is there a way to provide feedback as to what file...
2,586
Hi guys, A dumb question, but is it possible to pass values to tags using parameter files in Ftview SE ver 11? TIA
1,476
I am using a Global Object Touch animation to open up a popup window. Can you use one of the Parameters you pass though to adjust the visibility...
3,199
