FactoryTalk View SE 7 Alarm and Events
zacslade
Oct 2014
Phoenix, AZ
84
Hi all,
I'm working on a project with an existing HMI in FactoryTalk View SE local station 7.0 . I know that they do currently have alarms configured for this project.
I restored a backup (APA) of the existing program so that I could modify it, and I see that they have an explorer item called "AE_Server" with sub-item "Alarm and Event Setup". If I doubleclick Alarm and Event setup, I get an error, "Cannot connect to the Tag Alarm and Event Server. Unable to load alarm configurations."
I don't want to do anything which would cause me to overwrite or lose the existing alarms for this project, but I do need to add a few more alarms. Any advice, or ideas as to what's going on here?
Thanks,
Zac
Ive not come across this but as far as i am aware, the alarm/event server is based on SQL.
If its not letting you see the alarm configuration, id double check that the server is still set up to see the SQL server/pointing to the correct place
Ash
Thanks Ash,
I think you were spot on with this response. I was able to access the AE server by first disabling History in the AE_Server properties, Priorities and History tab (See technote 68418). I noticed that there was no database definition specified there, which was likely the reason I was getting the errors I was getting.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
148
Hi all. I´ve got a little problem with my FT View SE alarm window. On my PLC program, I have 200 SINT for alarms, in which every bit is for one...
203
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
349
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
452
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
560
