FactoryTalk View SE Alarm Log
ShadowFire
Mar 2016
Secunda
Good day,
I would like to extract the FT View SE Alarm Log. We currently have got a Excel spreadsheet set up with a connection to the FTAE SQL Database.
When I refresh the data, Excel give an error telling me that the data is more than what can be displayed in a spreadsheet. So it then discards the latest data. I have tried setting a database limit in the Factory Talk Administration console to only keep the last 60 days worth of data but it does not seem to take effect. I get data from January 2017. Is there a way to configure the ODBC connection in excel to only give me the data for the last 30 days or is there someone that can help me to limit the size of the database?
I have attached the current connection config.
Just use SQL Management Studio to purge old records manually. Or set up a SQL Job to do it periodically. Relying on FactoryTalk to purge old records is at best a 40/30/30 chance. 40% it works, 30% it doesn't, and silently, and 30% that it just corrupts the database entirely.
Yes, you can edit the connection string to select based on eventtimestamp. I have this at the office, but won’t be back in until the 6th
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
Hi all. I´ve got a little problem with my FT View SE alarm window. On my PLC program, I have 200 SINT for alarms, in which every bit is for one...
186
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
339
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
446
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
548
