FactoryTalk View SE and ODBC
Ok, I got it working. I forgot that I had to do a couple things. I had to add the odbc data source to the computer running rslinx and the computer running the hmi server. And then I forgot that I needed to do DataLogOn and DataLogOff.
Hi, i got the same problem under Windows 10 64 bit.
Thanks to Rockwell Support i could find a solution.
The solution for me was:
- Install/open the SQL Server managenment Studio
- Right click Security/Logins "New Login"
- Search "LOCAL SERVICE" and then ok
- Search "SERVICE" and then ok
For the new Logins "NT AUTHORITY\LOCAL SERVICE" and NT AUTHORITY\SERVICE
assing the Server roles "sysadmin"
Now it should work.
The explanation why you have "Test completet sucessfully" when you do "Test Data source", but it doesnt work in FactoryTalk View is that
when you test you connect to the database as local user, but when FTV tries to connect it does it as a service.
Thank you very much, crawler009! This works for me!!! 🍻
Now it should work.
Hello Rdrast!
I am facing the same problem as the one you posted the answer to. Unfortunately I didn't really understand the last bit of your explanation.
So, once you create the Logins 'SERVICE LOCAL' and 'SERVICE', what exactly do I need to put in FTView login? I would say I've tried every possible combination but the right one.
Thank you, Josep.
Hi Josep
in FTV you dont have to to anything. With this way you can leave the "Login requiered" unchecked, because the service has enogh rights to write to the database.
if you mean
this is done also in the SQL Server managment studio.
Edit: dont forget to restart the pc if it wont connect. FTV likes restart :)
Now it should work.
Worked and resolved the problem.
Thanks.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
116
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
177
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
