FactoryTalk View SE V10- Animate Screen Color?
Tanquen
Jul 2014
CA
163
V 10.00.01
Patch 6
Is there a way to have the screen backgrounds change color based on a tag value? Other than making a big rectangle and putting it behind everything on every screen.
Thanks.
V 10.00.01
Patch 6
Thanks.
FTView is not an object-oriented language, so as such does not expose much in the way of properties of objects.
I know in FTView ME that this is not possible. I've never worked in SE, I'm an Ignition man when it comes to SCADA, but I'd bet the mortgage payment that you can do this. Just do the rectangle, and make it a global object with a copy at the back of every screen. Once you resign yourself to the kluge, it hurts less and is over quickly. šŸ˜‚
On the display you want to change color, make the whole screen a panel and then the color you want, then use an expression to change the color.
Not sure how to do this and if itā€™s different than just using a rectangle and putting it behind everything as dcooper33 and I had mentioned.
Also looks like you can't make set it as wallpaper without losing animations. ???
Right. You can't use wallpaper AND have animation.
Using the rectangle object is best.
You could use the panel, but it has borders which you probably don't want. You could set those to none, but then you just have a rectangle that you should have used in the first place.
If you are using this on every display, then put it into a grouped Global Object.
That could include a header and footer (time date, alarm banner, forward/back buttons, etc) in the group as well.
That will make it easier to select and set to back on your displays.
In FTView Studio v9 you can hide an object during edits. Open the Object Explorer and uncheck the "background" G.O.
Can version 10 and 11 exist on the same computer without a VM Your attention is greatly appreciated Thank you
1,704
Not looking good but I want to simply show part of a string tags value but I see no way to do so a string display or text object. No text or...
4,611
I just upgraded my FTVME to version 10 from version 8.2. Now every time I try to get into my communications setup, it locks up the program. My PC...
3,280
I'm wondering if anyone here is running FactoryTalk View ME version 10 and has tried importing old 32 bit HMI project archive files, say going...
3,588
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,223
