FactoryTalk View Studio database error
corylee03
Aug 2018
Tennessee
Hey guys.
So I have a panelview plus 7 that I have uploaded the current .mer out of and converted to an .apa.
Once I try to open the .apa to view the graphics and what not, I get an error saying, "An attempt to attach an auto-named database for file C:\ failed. A database with the same name exists, or specified file cannot be opened, or it is located on UNC share"
Has anyone seen this before? It may very well be something im doing. I am still relatively green with FTV. Thanks in advance.
Here is something to check based on the Rockwell knowledge base... you need a tech connect contract to view.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/1041465
Right click C:\Users and select Properties > Sharing > Advanced Sharing and uncheck the box for Share this folder.
There is also a technote on Motoman software, if you have that installed could cause issue as it cannot exist on the same pc system as FTV studio.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/505640
Unfortunately the advanced sharing is not the issue. I checked to make sure that it was unchecked and it is in fact unchecked. I appreciate the article though.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
148
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
271
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
745
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
638
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
467
