FactoryTalk View Studio Displays
ftube
May 2013
Pennsylvania
Hello everyone,
I feel like this is probably going to have a simple response but I'm just a student and have been self teaching myself FactoryTalk View Studio.
I have a PanelView Plus 700 hooked up to my PLC. What I'd like to do is have a new display open when an input on the PLC is activated. So if N7:1 = 1 a certain screen will open whereas if N7:1 = 10 a different screen opens. I cannot for the life of me find any option to link a display to a PLC address though.
If this isn't clear or I'm not explaining it well please excuse me because like I said, I'm just a student who is self teaching himself and I'll gladly clarify anything that isn't clear.
Thanks for taking the time to read this and respond.
Yes, you can certainly do this. Under the System folder look at the Global Connections editor.
On the Display tab the Remote Display Number field can be assigned to an analog tag. Whatever value gets written to that tag commands the application to open the display with that number assigned to it. So have your PLC program write a value and the terminal will open that display.
Couple things to be aware of:
  • The displays must be assigned unique numbers in the Display Settings for each screen. All screens default to a value of "1". It is up to you to change that.
  • Write a value of zero to the tag to allow the terminal to take over control of which screen is displayed.
  • While you have a non-zero value in that tag, the user at the terminal will be unable to navigate away from that screen.
  • This setting overrides security. If the currently logged in user does not have access to a particular display but the Global Connection commands the terminal to open a specific display, the currently logged in user security is overridden and the display is opened.
Good luck!!
OG
OG
Thanks for the reply! I cannot find the display settings anywhere, mind pointing me in the right direction?
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
152
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
274
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
770
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
645
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
469
