Fanuc Proficy ?
jseavers
Oct 2005
Central WI
112
I currently have worked with Allen Bradley PLC stuff. What I am wondering is if Fanuc Proficy has a instruction like the SCP instrution in RS 500. What I would like to use it for is scaling analog inputs. Example, Input 0-32000 = 0-40. The plc that will be used is a GE Fanuc RX3i.
Thanks!
Yes
Use SCALE_INT to scale the analog 0-32767 to user units. Look in the help file for further info
Cheers
I have a really old "Proficy Process System 2.0 SP1" (which is now called PME). My problem is that i have a CPU module IC695CPE305 in the Rx3i...
3,265
Hello Everybody I have got Proficy edition 7.0 build 5517 and one of my customer has latest edition which is version 8.0 build 6215. He send me a...
5,176
When we upload from the 331 cpu it appears everything is being uploaded with no faults or warnings other than a name mismatch. No ladder shows up...
3,910
I've got to replace a Fanuc Micro IC620MDR014D 14 point PLC that has an "intermittent" run/program switch. I want to download the logic from the...
3,972
I want to Upload Project from GE FANUC 90-30 ,, i use Proficy Machine Edition V. 6 First i need to connect by COM cause it's only connection here...
19
26,340
