Fatcory Talk SE - VBA in Expressions
CCSTUART1
Oct 2016
Orlando, FL
I'm in tricky situation with SE. I'm fairly new to PLC programming / SE but very experienced in VB.
We have an HMI system which is network distributed. We have multiple tablets that connect to the server.
Some of the PLC / HMI logic requires us to know the name of the tablet, along with another variable that is only obtainable inside of VBA. (i.e CPU = Environ("Computername")).
I need to perform Expression logic on regular PLC tags AND these VBA variables. I cannot pass these VBA variables to the PLC to convert them to tags, or even to HMI tags, because these variables have to stay in the scope of the particular tablet instance.
I need to immediately be able to bring this "CPU" VBA variaible into a tag expression to evaluate / pass it along with real tags. I could do all of my HMI tag reads / writes / logic in VBA but our client does not like that.
Is there any way that I can, within one screen, set that VBA variable (CPU = Environ("Computername")) AND get "CPU" OUT of the VBA world and into a tag expression without needing to pass it to another screen as a /T parameter?
I know of no way, as all tag communications to a device (PLC) are handled by the FT Server. Clients don't do anything except communicate with the server. The only exception is that VBA is run locally, but tag interactions with devices remain server based.
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
55
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
84
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
71
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
248
