Fault display station
kayak1
Apr 2004
hello
I have to build line status and fault display station for 2 separate allmost identical lines building sliding doors for minivan. Both lines have sepeate DH+, each contains 7 AB processors : 5-5/40 and
2-5/40. I have to use what's available in spare parts crib(they won't spend money). I have a rack with 5/30 processor and panelivie 1400e or 1000e. I have to keep both lines on separate DH+ (same adresses for stations on each one). Both lines status and faults have to be displayd on same panelview. My question is , how do I bring data from both DH+ to my new display rack with PLC5/30 ?
what would be best solution for that kind of setup.
thanks
The only thing I could think of is to add the PanelView "e" terminal and the PLC-5/30 to one of the DH+ networks. The PanelView can get data from the local nodes on that network, and the PLC-5/30 can collect data from the other network and present it to the PanelView.
The elegant way to do this would be with a 1756-DHRIO module so you could bridge to both DH+ networks, but you would have to use something other than a PanelView "e" to communicate across that bridge module.
I have client files running on panel pc in different building all over our facility. I am wanting the display that is built for that building to...
2,333
Hey, I have an old panel that the plc has no display and flashing power and fault lights. I changed out the plc and now the new one powers up and...
4,359
I am currently working on a project that involves interfacing PowerFlex525 drives with a CompactLogix PLC over EtherNet/IP. One thing I have...
1,654
I have a 4 line display (OptiMate 640). I need to feed it the four highest priority faults. I currently keep track of faults in N7:50.xx where xx...
2,444
Hi everyone, Got some big problems here and I could use some help. I have a system that is using a 1769-L33ER along with 3 remote I/O Racks. 2...
7,964
