Faulty FM350-2 counter
finaben
Feb 2015
lagos
Any one with advice on how to resolve problem no count on FM 350-2 COUNTER MODUKLE. We have FM350-2 counter installed for counting of flow volume for our manufacturing plant and the counter has been working for about 6 months now and suddenly stopped working.
I replaced the counter after much troubleshooting and confirming that the flow transmitters are sending their pulse signals yet the new counter did not work.
Any one with experience on this should give me idea of how to resolve the problem.
Thanks.
Finaben
Hi, Need help with coding for a faulty component sensor which we are using a push button as we are using a test rig. the plc is a allen bradley...
225
Hi, i have a PLC B&R X20 CP3484. The machine was shutdown for months due to which I got to loose the plc battery, in the same time ethernet...
124
I am providing 24 volts on encoder input but getting the 24 volts on encoder output.The output voltage is not changing,so I want to ask what will...
2,355
This is a sort of research question. A small motor burned out (3KW) the bearings seized and took out the windings, that plus multiple resetting...
2,291
im a noob in need can someone help make a ladder logic system that can stop the production line when there is a faulty bottle, and two pneumatic...
1,441
