FB284 (SINA_POS) for Step 7?
CBE
Jun 2017
Sweden
Hi!
I'm working with a project consisting of:
Simatic Step 7
CPU315-2 DP (6ES315-2AG10-0AB0)
CU310-2 DP (6SL3040-1LA00-0AA0)
PM240-2 (6SL3210-1PE22-7AL0)
SMC20 (6SL3055-0AA00-5BA3)
Motor (1FT6084-1AF71-1EG1)
I have successfully programmed my CPU to run the Servo via ProfiBus with the block FB283 and a VAT-Table.
In an earlier project I've used a S7-1200 (TIA-Portal) to run a S120-Drive via ProfiNet and the block FB284 (SINA_POS), which was very easy to use.
Is there anybody out there knowing if the FB284 (SINA_POS) exists or if anybody have made one for Step 7?
Best Regards
Christoffer
That's right!
Have used that example already as explained above and now wonder if FB284 (not FB283), which is easier to implement, can be found for Step 7?
Ive only seen that exact block in TIA Portal
In Portal theres a 300/400 version and 1200/1500 like you stated
I think the Sina POS for positioning and Sina Para for parameter read/writes is easier.
I have my own Telegram 111 block for Step7 V5.x :)
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
226
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
146
Hello all, i am new to the servo drive and this brand also. i installed the automation studio v4.12. i have to configure drive with plc B and R...
377
hi goodday to all, i have acopos 1320 as below title my acopos not driven a servo motor,. please help me,.
454
Hello, Does anybody have experience with ACOPOS drives? One of the machines at my plant uses B&R system with three ACOPOS 1016 drives. All three...
1,464
