RMA
Depending on the circumstances I use both of the tricks mentioned above.
Either make a copy of the FC which is called multiple times and substitute it in one call for the original FC or else create and open a dummy DB (so as to be able to easily define the View path) before calling the particular instance of the FC you want to monitor - this is dead easy in STL, possibly not quite so easy in ladder, but as you may have noticed, STL is much more widespread this side of the pond!
