fetching data from HMI
Feb 2011
karachi
A S7-300 PLC is connected to an HMI and live data is being displayed on HMI. I want to fetch this data from HMI into a windows based PC. Is it possible, if yes please help me how.
opc
Do you need the data realtime ?
If that's the case, then I think you should go for OPC.
Ok I've never used Siemens HMI's before so I'm not much help to you. If it was Proface they have software to extract data from the PLC but with Siemens I'm not too sure.
Not realtime
If you do not need it realtime, then you could write a script that is called on tag change event. You make a tag connected to a PLC variable that changes every x time. The tag has to be polled continuesly. In the script you can take the needed tags and write them to windows text files or csv files. Check this forum for more information.
yes it is siemens HMI
Hi; In my O/G facility we are using Wonderware Intouch ver 9.5 for SCADA. We need to automate the process of exporting realtime process values for...
2,547
Hi, our company has just switched from older Modicon PLCs to S7 (5x317/2x317F) connected over ProfiNET. We use InTouch 9 for the visualisation...
3,043
I know this forum is for PLCs but maybe someone also does iFIX. When a chart configuration window is opened there is a checkbox called Fetch...
1,759
Hello, im quite new and still learning. I would like to ask is it possible for FATEK PLC to read data value more than 16k? I'm trying to move my...
74
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
138
