L D[AR2P#0.0]
For the record, I do not have to set the .IN in a seperate network, or seperate FB (or OB), but if it is a BOOL I can simply place it directly onto the IN of the SFB4(5) where it is programmed. Correct?
If I place a time value on PT do I need to reset this on start-up in OB100?
I would not normally assign the .IN in a separate FC/OB - the example I posted earlier was to show how you could use SFB4 timers without having to create a separate instance DB for each timer use. My normal use is to incude SFB3/4/5 timers in the stat area of a function block and only reference these timers from within the FB.
