Fisher Rosemount DPR 950 manuals????
mordred
Mar 2004
Red Deer
1,892
Been trying to find a copy of the Fisher Rosemount DPR 950/960
manuals as I have a rather unusual problem with a controller that runs a mucossa/hepburn application. Rather than try to explain what the application does I'll describe the glitch instead to explain the other could take too long. This temperature controller runs the steam heating system for 2 digesters/ribbon blenders. The PID controls works reliably and maintains the temperature within 1 degree of setpoint as the digester fills up however with a setpoint of 60 degrees celcius if the current temperature is outside of that SP by 15 degrees the controllers goes haywire and the temp will climb steadily well beyond setpoint. What I've determined so far is that there appears to be 3 different PID loops all with the same settings K1 to K3 2.00 TI to T3 210 TD1 to TD3 30. However I cannot find the copy of the manual we used to have so I'm looking to replace that copy so I can figure this out any help would be handy I've been trying but the search engines have been unsuccessful thus far
Looks like this component is too old for anyone to have the manuals handy however was at least able to get into the parameters screen soI'm halfway there
Any chance someone still has the the DPR-950 manual available?
It would be much appreciated!
sbiela @ pac-llc . com
Thank you!
Thanks guys, you’re my last hope. Is it possible I can get the manual as well? Please kindly send to colinxa @ yahoo dot com. Thanks in advance!
Not to continue to necro this thread, but if anyone sees this and has the manual. Can you send it to sweetbabydiesel @ gmail.
Appreciate it in advance!
I currently have the DPR 960 V 0. Can I replace it with a controller With V 1? Same part number just different versions. Is there difference...
1,567
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
287
Does anyone know where I would be able to find the modbus driver for Kingfisher Series 2? (CP-11 CPU). Toolbox32 is asking for a *.d32 file...
1,391
PLCS does not have much information on ROC FST programming, as it is an RTU for the Oil and Gas sector, Now that I have taught myself a bunch, I...
49
23,875
Hello all, I am doing a rebuild and I need to transfer two Thermo Fisher weighbelts (Model MT2201 PM) from an old system to a new one. For that...
1,196
