Fix32 7.0 Sim driver counters
DoomQuaker
Feb 2008
The south
I'm using the internal counter "C:UAA" on the SIM driver to check for any unacknowledged alarms in area "A". My question is: does it exist a similar counter, only with the difference being that it checks for alarms that are ACTIVE and unacknowledged?
Thank you,
M
Thank you for the PDF.
So it seems that there is no counter for unacknowledged and still active alarms. Too bad, since the counter is used to signal important alarms all day, year round to the technichians. It would be perfect to filter out alarms that "solve themselves" after a short time to minimize the need for the technichians to drive to the Fix station only to find the alarms merely needing an acknowledgement. But that doesn't seem to be possible...
Once again, thank you for the help,
M
That might be something that the controller(s)(PLC's) that FIX is connected to can generate. Then just have FIX poll that value.
Thank you for the answer.
I would think that doing this would result in too much work, since there are just too many plcs, all of different kinds, to deal with.
Since there seems to be no way to check for active alarms, I can't see any easy solutions to the problem...
Its never easy. Job security.
I would love to see Sweden.
I have a a PLC-5 system that is connected to a Windows 2k PC that is running Fix32. I was called to reload the program onto the PLC-5 and I did...
1,303
Good day folks, i have a question, maybe have someone the installation for LNI drivers (lonworks network interface) for fix32 i need it for an...
1,075
I was introduced to Intellution Fix32 scada software at one of my customers today. They have no support from the programmer that built this setup...
6,009
Hello all, I'm using Fix32 7.0 and I would like to communicate with an OPC server. As I understand I need to install an OPC client driver? Where...
3,456
Hi All. I have an old Windows NT machine that has FIX32 running on it. I've added a network adapter to the computer and now Fix32 Startup is...
1,496
