Fix32v6.15 moving SLC's from RS232 to NETENI's
AndrewB
Aug 2003
165
hello
I have an fix32 V6.15 box talking to 2xSLC503's via serial.
I am stuck with fix32 at the moment but i do have the following bits i can use:
2x 1761-NET-ENI's
A spare linx OEM liscence.
a very nice industrial ethernet
What i would like to do is use the net enis on the SLC's but I am not sure what to do as far as FIX32 goes.
There are only comm port drivers in the ABH thingo.
should i use a comm port software redirector or is there something to fix up fix32 to use linx as an OPC server???
The "ABR" driver is what you need. It uses Rslinx to communicte with the SLC and FIX then uses the ABR driver to poll for data ( see site below)
Just one comment though, I don't see much of an improvment over what you have now. You will still be communicting with the processors by way of there serial port. If fact you will just be adding more stuff in between the PC and SLC. So the question is
why?
http://www.gefanucautomation.com/products/fixiodrivers/showdrivers.asp?objid=418
I'm a Siemens person, and this is one of my first AB programs. The customer wants everything programmed in Ladder. I have a lot of data (3...
233
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
255
Hello, i am a beginner with a Siemens Logo 8 PLC. I would determine the direction of an object if it passes a whole cycle of 2 input sensors. See...
196
Can an AOP be removed from Logix? I seem to have some version weirdness from an E&H AOP and I need to see if reinstalling the AOP will correct it.
984
I'm making a meal of this, my brain's not in gear. Also, I'm new to S7 TIA/WinCC so excuse my ignorance... See redacted pic. Pressing F7 (SAVE...
3,226
